Endothermic/Exothermic new combustion cycle.
I have a need for some smart chemical professionals!
My problem:
I am in the process of making a test system to test a new combustion cycle. The problem is that I need a few chemicals and they need to have certain special qualities.
First: I need to know if there are any endothermic processes that involve Nitrogen? if there is what are they?
Second: I need to know if there is an endothermic process that results in a solid that can react exothermically with petrol/ethanol/iron/aluminium...
Also because my knowledge in the field of chemicals is fairly limited I would like the common names if possible (but don't forget the technical details).
Thanks in advance for the help.
My problem:
Current project car: '98 BMW 316i
Main targets: 950kg, 250rwhp, min. 1G lateral grip. Special: Twincharger system, hydraulic ebrake, New suspension.
RE: Endothermic/Exothermic new combustion cycle.
