curve defined by an equation
Hi!
I'm trying to draw a parabolic curve and I'd like to know if there's any way to do it by introducing a table of values(x and y) or by introducing a formula as y=x^2
Thank's very much for your help
RE: curve defined by an equation
That's a very simple formula to setup.
Do you know how to setup parameters?
Catia Design|Catia Design News|Catia V5 blog
The Parabola y = x2 is a unique Conic, and is a curve that can be created direct in Catia:
Insert => Wireframe => Conic.
A simple example is a parabola that starts at (1,1,0), ends at (-1,1,0), has a vertex at (0,0,0) and a directrix at (0,-1,0) - this is the tangents intersection point. The Parameter  for a parabola is 0.5, parameter values [0>P<0.5] are elliptical, those [0.5>P<1] are hyperbolic.
The only difference between any parabolas is the Scale, so whatever values you have for the parabola dimensions, the point values can found from y = x2 ; the tangent intersection point is always minus the 'y' value of the start and end points.
check the online documentation for Creating a Curve From Its Equation
Then if you have question on this, tell us more about your problem, but everything is detailed in the DS doc...
Eric N.
