How do I check for a closed profile within a complex sketch?
I've imported a set of lines into Solidworks from AutoCad and I want to perform an extrude with these lines.
Unfortunately there must be gaps in the profile because extrude won't work. I've tried selecting the 'contours' (where it turns red within a closed profile) but that's not coming up either.
Is there a way to check whether certain lines within a sketch make a closed profile?
I've tried using 'extend' then 'trim' but that hasn't worked, and because there are lots of other shapes within the same sketch I can't use a simple extrude so i've got to select the contours individually.
Thanks!
Thanks!
RE: How do I check for a closed profile within a complex sketch?
What does 'fit spline' do? Would that work?
