UG-45 calculations for manways
Dear members
What is your opinion regarding the requirement of UG-45 (Min. nozzle neck thickness) calculations for manways?
Are such calculations mandatory even for manways?
Waiting for the replies.
RE: UG-45 calculations for manways
Cheers,
br2vessels
UG-45(b) applies to "nozzle neck or other connection, except for access openings and openings for inspection only".
Thus UG-45(a) applies to all such connections, but UG-45(a) appplies only to "process-type" connections, not to "access" openings.
"Thus UG-45(a) applies to all such connections, but UG-45(b) appplies only to "process-type" connections, not to "access" openings."
Thank you for your input.
