When do you need a Building Engineer 24-hours a day?
Hello all,
We have a kitchen application using a steam boiler for kettles rated at 1800 LBS/HR. We were recommending two boilers sized at 2/3 each for continuous operation during maintenance and redundancy.
At what Boiler Plant capacity does one need to have a buidling engineer 24-hours per day in the boiler plant?
Thank you
Thank you
RE: When do you need a Building Engineer 24-hours a day?
ยง[C26-1402.1] 27-795 High pressure boiler operating engineer license. -If a boiler produces steam or vapor or has a safety valve setting of more than fifteen psi and rated in excess of ten hp or if such boiler produces hot water at a pressure of more than one hundred sixty psi or at a temperature over two hundred fifty degrees Fahrenheit, such boiler shall be operated by a highpressure boiler operator licensed in accordance with the requirements of subchapter two of title twenty-six of the administrative code.
http://www
Thanks for taking the time and deliver a very fast response.
Since it varies with locality,is there anyone out there in West Virginia?
