Sheet size
Sheet size
Looks like i'm facing difficulties since started using v5 after some time.
I'm using A0 Size sheet size for dwg & due to extensive detail dwg, I crossed the limit of sheet size.
One way, I can see to reduce the size of view that I don't want to do so any other suggestion?
RE: Sheet size
Contextual menu sheet 1 --> properties.
Display toggle
or
Change the name of the sheet, press tab and voila?
Derek
RE: Sheet size
If not, you can always add a second sheet, and then cut&paste some of the views from Sheet1 to Sheet2.
RE: Sheet size
Does someone have solution?
RE: Sheet size
Anything outside the limits of the sheet will not print.
fname
RE: Sheet size
To do this RC over SHEET.1 go to properties, change the format name and then hit your TAB key, you now are able to change the "width" and "height" of your sheet.
RE: Sheet size
Can you tell me how to customize sheet format?
RE: Sheet size
In your drafting page RC over the label "SHEET.1"
in the properties page you can change your sheet size as explained in the above response.
Do not change your sheet size by the drop down box, just change the name manually, then hit your tab button (do not hit enter at this time or it will close your property page)
You should then see the "width: and "Lenght" boxs turn white.Here is where you can change your paper size.
RE: Sheet size
