update issue for dwg
I have 3d model & working on associated detail dwg.
As you know, when we draw the view from 3d models than need to delete a lot of extra lines to avoid misunderstanding.
Also, I deleted section line hatch mark.
Now, Even there is no change to model, sometimes i receive update command while opening dwg & when I click the update
it will mess my dwg. like section hatch will show up again on dwg etc.,, so I delete again...
THe 3d model I received from customer
RE: update issue for dwg
If it is a file you recieve from the customer could you isolate the drawing?
Derek
