Explode in 2007
Explode in 2007
Explode in 2007
   We have just upgraded from SW2003 to SW2007.  I am trying to figure out how to explode assembly views.
   On SW2003, it is possible to select component patterns for exploding purposes.  All you have to do is select an original pattern component.  That component plus any other pattern components you click on will select the whole pattern.  This seems to be missing on 2007.
   Is there a way in SW2007 to select pattern by pattern?
                         JHG
RE: Explode in 2007
The explode command recognises them as individual components.  If you pick them all it does group them together.  So the answer to your question would be no as far as I understand the command.
Best Regards,
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he'
RE: Explode in 2007
While you can't simply select one of the components of the pattern, thereby selecting the whole pattern, you can expand the pattern in the flyout tree and shift select the parts there. Quicker and easier than clicking on each part.
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
RE: Explode in 2007
   Thanks.
   One step forward, two steps back.  I have been selecting from the flyout tree, but it was no nice to get the whole pattern with one click.
   Oh well.
                      JHG
