Colors In Drawing
Colors In Drawing
Colors In Drawing
I have a multiple sheet drawing. I tried to change a line color by modifying the "component line font" for sheet-1. I didnt like the results so I changed it back. When I tabbed over to sheet-2, I noticed that it had changed colors also. So I changed it back to the default line-font. But then the sheet-1 changed colors again. And this goes back and forth. IS there a way to get all of my sheets back to the default line-font (black)?
Thanks.
RE: Colors In Drawing
Reload your sheet format. RMB on sheet format in the FM (you'll have to do each sheet separately), select properties. Browse to your template location, select the template, open then 'ok'. This should reload the sheet format and reset everything...
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
If you use a program like Propa-Gator you can change the sheet format en-masse.
cheers
that did it. thanks.
My pleasure!
Unless, of course, you're thanking CBL, then, I guess, it would be his pleasure...
Jeff Mirisola, CSWP
CAD Administrator
