cant insert details into asm
I keep getting an error - "open clipboard failed" - every time i try to insert a part into my assembly file.  Im running sw2007.  Ive got the newest sp. Anyone have any idea what the problem could be?
RE: cant insert details into asm
Can you just drag and drop the document?
Have you tried using the Design Library or File Explorer?
Can you use the File > Open method?
cheers
I'm sure if you search the forum here you will find other postings on that.  I think it may be a Microsoft problem as much as anything.  That error showed up for us when we switched from Windows 2000 Pro to XP Pro.  It is fairly random when it happens.  I can usually get around it by browsing again to the part that you want while still in the insert part command.
mncad
