Assembly failure - cannot find components
Hey all,
I have recently started having this problem with assemblies Pro/E (WF 3).  I created an assembly and insert a sub assembly into it.  This sub assembly is used in a number of things here and so it is in its own folder.  Everything is working fine when I close Pro/E.  When I try to reopen my assembly however it cannot locate the sub assembly and I have to locate it manually, or delete and re-insert it.  Is there a way to get Pro/E to remember where it is?
Thanks!
Matt
RE: Assembly failure - cannot find components
You can use a search path in your config.pro file.
