Favorites + paths in config
Where is the "Favorite" paths saved, i have found some in the config file, 6 out of 10, but i cant find the remaining 4.
I have also some problems with loading textures to assigned colors, seems WF isnt reading the paths in the config file. Are there any limitations in path naming, could i use # / & in the file names or path names ?
Are using WF2 and Intralink.
Texture and color files are located on harddrive, not in CS or WS.
RE: Favorites + paths in config
Peter Stockhausen
Pollak Switching Products
It's handy to put a short-cut in your 'My Documents' folder that teleports you to a C:\MyDocuments directory (no space)...
<tg>
Ben Loosli
Sr IS Technologist
L-3 Communications
