What is the bulk density for plastic pellets?
To all,
I would like to know the detailed definition for bulk density which was applied in PE or PP pellet. Also, if the materials were ground, can I said that bulk density will be increased than before?
Chiu22
Chiu22
RE: What is the bulk density for plastic pellets?
Finer particles usually have a higer bulk density because they fill in more void space.
Good luck,
Latexman
So it's important to measure a representative sample of your product when checking a bulk density and use a container commensurate with the particle size of the material.
