Vessels category per IS 1893
Hi gents,
I am using the Indian seismic standard IS 1893, to specify the design conditions for a number of vessels operating in a gas plant. I found very confusing, the categorization of the vessels, particularly the definition of vessel failure. I am tempted to put every vessel in category 1, knowing the consequences of vessel failure in a gas plant..However, the IS 1893 appears to include in category 1 only the vessels which would affect the population beyond the plant boundary line. Could anyone shed some light on this classification, given my limited experience with this code.
Cheers,
gr2vessels
Cheers,
gr2vessels
RE: Vessels category per IS 1893
you also need to consider the surounding pipelines, vessel, etc hazard level.
There is no reference to any hazard level in the IS 1893, can you please point me a bit closer to the hazard factor in the seismic standard?
gr2vessels
