Capacity of a welded joint
I have a very basic question. I would like to know the capacity of a welding. I want to calculate the capacity of welding a 7/8" diameter Hilti Super HAS threaded Rod (10inches long) perpendicular to a 1/2" thick steel plate. Using E70xx electrodes and regular steel
how can I get the sheer capacity of lets say 5/16 thick welding in this configuration?
thanks
Tomaz
thanks
Tomaz
RE: Capacity of a welded joint
http://www.welding-advisers.com/
