Looking for ASME equivalent to G40.21-44W plate?
3
I've designed a 26"-300# knife gate valve and am required by Alberta's Boiler and Pressure Vessel safety association to identify all materials by ASTM/ASME specifications. I come from an industry where all I know is ANSI designations ie. 4140 HTSR, C1026, etc.
I've managed to nail down 90% of the component materials with ASME specs, thanks to this forum and other resources, but I am completely stumped on this structural plate. Normally, I would specify A-36 plate, but to my knowledge any plate over 2" thick becomes G40.21-44W structural plate.
The component is a spacer ring between the valve body and the flange (I'm using A-105 for the flange and A516 Gr. 70 for the valve body plate). The ring dimensions are 30.25" OD x 26.25" ID x 4.50" thk. I opted to flame cut or water jet the rough ring out of plate and then machine to finish dimensions.
If anyone knows of an ASTM/ASME spec that would apply here I would be eternally grateful (it must be a weldable grade steel).
Thanx again
RE: Looking for ASME equivalent to G40.21-44W plate?
You may want look at this pdf.  I am not really sure if this is what you have been looking for.
http://www.algoma.com/media/sheet.pdf
CSA G40.21 38W (280W)
ASTM A1011-SS Grade 36 Type 1 and Type 2, ASTM A907 Grade 3
Hope this helps.
Rao Yallapragada
Pulling from the back of my brain;
For pipe supports; CSA G40.21-44W can be substituted for SA36 except in elevated temperature applications (value escapes me right now).
I have never heard of using A36 (G40.21) in valve construction.  You might want to review that.
Frank "Grimey" Grimes
You can only trust statistics 90% of the time.
The material spec in question is already ASME certified.  Refer to ASME Section II Part A (page 1637 of my edition)and you will find the spec you are looking for titled SA/CSA-G40.21.  If you call off the material accordinlgy, you should have no more problems.
