Help determining "n" values of stream channels
I got into a heated debate with a municipal engineer about the "n" value of a stream channel adjacent to a site I was designing. He was being very conservative and it was painting an ugly picture hydraulically. Determining "n" values seems very subjective and I couln't find anything to rebut his position. I found some examples at the USGS website but they were drainage areas of 50 square miles plus. The drainage area of this channel was only 750 acres and the USGS examples didn't help much. Anyone know of any source to help in determining the "n" value?
RE: Help determining "n" values of stream channels
* Open Channel Hydraulics by Ven Te Chow, 1959
* Handbook of Hydraulics by Brater, King, Lindell, & Wei, 1996
* HEC-RAS Documentation
As francesca said, the value will probably vary with depth, so you will have to use one of several techniques to determine a composite value. (Horton, Pavlovskii, Lotter, etc.) But some routing procedures subdivide the flow across the channel, rather than attempting to determine a single representative Manning's value.
What values are you looking at?
http://wwwrcamnl.wr.usgs.gov
Do try different values as suggested by Blueoak to see how the n value affects the calculated depth of flow.
good luck
Keep in mind this all came about because he wanted the basin above the 100 yr flood plain. The FEMA map said the project was well upstream of the 100 yr flood plain and I thought that was enough in itself.
In a 100-year storm event you're likely to get tree limbs down and other debris in the channel. I would be inclined to use the higher number for the sake of being conservative.
As regards FEMA maps, in the area I worked, the FEMA maps were developed in 1974. The area had undergone significant development since then and they were relatively worthless; good for a ballpark estimate, but not so good for setting finished floor elevations. If your Manning's n-value is being problematic with regards to the bottom of your detention basin, then the guy was right, you're not far enough upstream of the 100-year floodplain. If you were, it wouldn't matter what n-value you picked, your detention basin would be unaffected.
http://manningsn.sdsu.edu/
Scott367,
When I did small channel design we typically used 2 n values (and of course looked at the sensitivity of our model). First was a cleaned channel which typically was about 0.02 to 0.025 and then a roughened channel of anywhere from 0.035 to 0.05 depending on how well established we thought it would be to how much maintenance we expected. I am most comfortable with 0.025 really only for soon after initial construction if it will be used to define a high water line.
The only reason we even looked at the smaller n value was to make sure that the channel was stable until we could get vegetation established.
You have to look at the fact that a clean smooth straight channel with no vegetation starts off with a base n of about 0.015 to 0.016 just for soil to water interface(USDA-ARS Agricultural Handbook Number 667). For storm based flows rather than a continual feed of a canal it would be more consistent in a general sense to see 0.035 used, but of course this is site specific. (0.035 doesn't seem high to me)
As you consider your n value you may wish to consider maintenance. Is it only once a year? Weeds only take a few weeks to establish and effect flow parameters. If it will be maintained and mowed regularly a lower n value may be more appropriate.
Many times, the channel, if incised, will contain the flows with minor changes in elevation (Supercritical flow).
Overflow is a different problem, with n vlues increasing as a function of slope. The flatter the slope, the greater the n value. The change in results will still be minimal.
