pour concrete slab 4"thick on exxisting concrete slab
have to pour slab on existing concrete slab and need to know how to bond the two together.do i need to use rebar,wire mesh or can use fibermesh concrete.
thank you for any advice on this matter.
RE: pour concrete slab 4"thick on exxisting concrete slab
Also the new slab will shrink and the old one wont, so if you bond the two together then be prepared for lots and lots of cracks (even with reinforcement).
