DIMENSION JOG
DIMENSION JOG
DIMENSION JOG
I'm trying to find a different way to access the dimension jog other than RMB DIM -> DISPLAY OPTIONS -> JOG/UNJOG.
When trying to tidy up a drawing with hundreds of dims, the process mentioned above takes about 4 secs, not to mention too many mouse clicks.
I haven't come across a jog command button, keyboard shortcut or macro to help shorten this procedure.  Any help would be appreciated.
thanks!
RE: DIMENSION JOG
If you are trying to add the ability to jog dimensions, you could box-select all of them then do the RMB thing. This will allow every dimension to be jogged manually.
cheers
RE: DIMENSION JOG
Thanks C.
The problem then is when zooming out to get a bird's eye view of what needs to be changed and multi-selecting each individual dimension is that I generally lose my ability to select accurately, thus causing other problems.
I've sent this as an enhancement request, but I'm sure it isn't at the top of the list.
Thanks for the feedback.  Congrats on Tip King of the Week.
RE: DIMENSION JOG
That's why I mentioned doing a box selection of ALL the dimensions. The ones that are already jogged will remain jogged, but the ones that weren't jogged will become joggable.
... and thanks for the congrats.
cheers
RE: DIMENSION JOG
Here's a macro you can map to a keyboard shortcut.  To use it, select an ordinate dimension and run the macro.  It will toggle the jog state of the dimension.  It currently only works for one dimension at a time.  As posted it will notify the user with a message box if the selection set is inappropriate (more than one item selected, selection is not a dimension, dimension is not ordinate).  If you don't want to see the notification, change the value of NOTIFY_ERRORS to "False".
Let me know if you want to be able to run this on multiple preselected dims.
CODE
Const NOTIFY_ERRORS As Boolean = True
Dim swApp As SldWorks.SldWorks
Dim swDoc As SldWorks.ModelDoc2
Dim swSelMgr As SldWorks.SelectionMgr
Dim swDim As SldWorks.Dimension
Dim swDispDim As SldWorks.DisplayDimension
Sub JoggleToggle()
Set swApp = Application.SldWorks
Set swDoc = swApp.ActiveDoc
Set swSelMgr = swDoc.SelectionManager
If swSelMgr.GetSelectedObjectCount <> 1 Then
    If NOTIFY_ERRORS Then MsgBox "Select a single dimension and run again"
    Exit Sub
ElseIf swSelMgr.GetSelectedObjectType3(1, Empty) <> swSelDIMENSIONS Then
    If NOTIFY_ERRORS Then MsgBox "Select one dimension and run again"
    Exit Sub
End If
Set swDispDim = swSelMgr.GetSelectedObject6(1, Empty)
If swDispDim.GetType <> swOrdinateDimension Then
    If NOTIFY_ERRORS Then MsgBox "Dimension was not ordinate"
    Exit Sub
End If
If swDispDim.Jogged Then
    swDispDim.Jogged = False
Else
    swDispDim.Jogged = True
End If
swDoc.ClearSelection2 True
swDoc.GraphicsRedraw2
End Sub
RE: DIMENSION JOG
SSSSSWEEEET.  That is exactly what I needed.  Mapped to the handy "J" key and off I go.  That's great.
If you have one already for a multi-select, I'll be glad to put it in the arsenal.  "K" is sounding good about now.  Otherwise, no worries.  This first one should meet most of my needs.
Thanks a bunch.  Been a great help.
RE: DIMENSION JOG
I went ahead and wrote the multi-select version.  It's actually a bit shorter.  Any inappropriate selections will simply be ignored.  Enjoy!
CODE
Dim i As Long
Sub JoggleToggleMulti()
For i = 1 To swSelMgr.GetSelectedObjectCount
    If swSelMgr.GetSelectedObjectType3(i, Empty) = swSelDIMENSIONS Then
        Set swDispDim = swSelMgr.GetSelectedObject6(i, Empty)
        If swDispDim.GetType = swOrdinateDimension Then
            Else
            End If
        End If
    End If
Next
End Sub
