Flex circuit molded into plastic cavity?
Can a flex circuit withstand this?
Proposed design: flex circuit 'sandwiched' in plastic housing. Subjected 2 times to temperature of 320C (608F) in a mold cavity for prolonged period - possibly a minute to cure plastic (Lexan GE #940). Any feedback appreciated.
RE: Flex circuit molded into plastic cavity?
Plesae read FAQ240-1032
My WEB: <http://geocities.com/nbucska/>
Maybe you could support it by the conductors. If you brought all the conductors out to the edge, and had eyes in the ends to mate with pins in the mold, and all the conductors were straight like little tie rods, maybe you could get away with it. You'd have to trim off all the dangling eyes, etc as a secondary operation, and be careful about not leaving any on the mold for the next part.
I'd call it a high risk, high cost experiment...
Mike Halloran
Pembroke Pines, FL, USA
What about jigging the wire paths in and using the injection media as the "cable housing"?
You realize that IC makers run injection plastic thru the forest of microscopic 60AWG(?) gold wires that are bonded from the lead frames to the ICs billions of times a day without breaking the bond wires.
Keith Cress
Mike Halloran
Keith Cress
I have also done an embedded cell phone antenna on a polyamid flex circuit which was molded in an ABS sandwich. I do not believe the cure temperature was as high as you describe, though. Do you really need to use lexan?
