A new hole in Rev 17 it will have 3 Activity parameters
Has anybody else seen this?
When you create a new hole in Rev 17 it will have 3 Activity parameters. This causes our rules and reactions to fail when we deactivate or activate a hole. To reproduce, create a hole and open the formula editor. When you select the new hole you see...
DrillHole/Hole.1/Activity true
This did not happen on Rev 16. If anyone has a solution or workaround, I'd sure like to know. Thanks in advance.
RE: A new hole in Rev 17 it will have 3 Activity parameters
Derek
