heat transfer coil in solar cylinder
Hi
Does anyone know a simple formular for working out the area of the heat transfer coil required in a solar heating system:- for example a formular linking area of heat transfer coil to the area or kW output of the solar panel. The transfer liquid is water+antifreeze......Or is it more complicated than this?
RE: heat transfer coil in solar cylinder
