role of plenum in forced air cooling of electronics
I need to understand the role of the plenum in forced air cooling of electronics, please.
I have observed two quite different types of structures being called plenums, though they may operate on the same principle.
First is a fan fed box (typically a scroll type fan) from which air goes to an electronics enclosure that needs cooling - one subject housing, no distribution, and the enclosure inlet may be similar size as the fan outlet. This suggests to me that the plenum has a role that is principally one of pressure management?
Second is a structure, again fan fed, that increases, perhaps many times the sq area of the fan outlet - such as feeding a heat exchanger or a filter. Is this a plenum also?
Any references or guides on sizing and designing plenums (plena?) particularly the second type (I have searched).
Thanks in advance,
NigelT
Thanks in advance,
NigelT
"You will master any feeling of inadequacy you may be having"
....from my fortune cookie @ the buffet!
RE: role of plenum in forced air cooling of electronics
I have designed electronics enclosures that contained things that I refered to as plenums, or that I could have called plenums if I had wanted to.
You should try to figure out what problem the designer is trying to solve. Generally, I am trying to fit a dust/EMI filter in front of the fan. These cause head losses, so I select ones that are significantly bigger than the fan, as you have noted above. This causes fit problems that are easily solved by a transitional structure of some sort.
In the past, I have fallen into the trap of thinking that air on the high pressure side of the fan has more cooling capacity. The effect, whatever it is, is negligible. The pressure heads of ventilation fans are small compared to atmospheric pressure.
JHG
Cooling Techniques for Electronic Equipment by Dave S. Steinberg published by John Wiley & Sons, inc
http://www.efisystemsgroup.com/system.htm
http://www.coolingzone.com/
Best Regards,
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he'
