Formating hard drive
I'm currently trying to format my hard drive and I was wonder if someone could tell me how to. Its been awhile since i've done anything like this! thanxs
RE: Formating hard drive
1. Make sure you back up the data because once formatted theres no going back
2. Make a bootable floppy & make sure the FDISK and FORMAT commands are copied on it from C;\Windows\command\
3. Boot up from your floppy and if required run FDISK to partition your hard drive.
4. After FDISK then type Format C: /u/s
(This does an uncondtional format can copies the system files)
5. Then load your OS.
Now although these instruction will get you through they do assume you lnow a thing or two.
If you can't make head nor tail of them then look at the following links for info
http://www.5starsupport.com/info/format.htm
http://www.5starsupport.com/info/partition.htm
http://avenir.dhs.org/articles/software/formatoften.html
http://nj.essortment.com/harddrivemaint_oks.htm
Any help ?, yes no let me know.
