Solid Edge Drafting
Solid Edge Drafting
Solid Edge Drafting
Can anyone tell me how to delete a section line from a view? I am working with some fairly complex drawings from a customer and need to redo some sections. I can delete the section views but haven't been able to figure out how to get rid of the section line and its designators from the parent view.
Thanks - Dave
RE: Solid Edge Drafting
If I've understood correctly....
Select the line and hit delete should do it.
You may need to hover over the line and use RMB to select the correct entity.
May be: right click on the view and choose 'draw in view'. May be someone drew something manually inside the view... Delete it.
HTH
Fred
