Transition Temperatures
Does anyone know the lower and upper transition temeratures for ASME P1 materials? Specifically SA-53 GrB
and if so where is a good place to find this type of info for future reference?
RE: Transition Temperatures
Ah, Ok, you need information on the lower critical transformation temperature. For P-No 1 materials, per ASME B31.1 (Table 129.3.2) use 1340 deg F.
