Decimal Place Settings
3
Ok, here's another simple (stupid) question. When I measure things in my parts and assemblies it only gives me 2 decimal place accuracy. Also, when I dimension my drawings everything shows up a 2-place decimals. How can I increase that to 3-place accuracy?
Dblcrona
RE: Decimal Place Settings
Open a new document then go to Tools > Options > Document Properties > Units. Set the settings to what you need and save as a document template.
cheers
Also when you have the measure dialog box active you can hit the Units/Precision ICON and change the units or decimal places for that function.  I doesn't affect the document settings.
Best Regards,
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he'
Can you change the units/precision in eDrawings?
Brian
MN5520, I have asked the same question many times and so far the only response I got was no.
If the creator of the edrawing has enabled measuring in the file, you can set the units you want to use to measure. I didn't see any way to change the precision though.
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
