How do i delete a hole table in solid edge V14
i cant seem to delete a hole table i have placed, i cant select to delete or edit. there also seems to be no way of editing an existing table. any ideas?
RE: How do i delete a hole table in solid edge V14
Click the select tool (yellow arrow), then click on the icon at the top left called 'select options' i believe.
In this dialog box, make sure 'active layer' is not checked.
This should let you select your hole table I think.
HTH,
Fred
Cheers
I think that this option ( 'active layer' ) sometimes has
a life of it's own, even when set to 'OFF' it reverts back to 'ON'
from time to time (V18/V19)
dy
