Configuration Management Documentation
I have just started a new job as a Desktop Engineer for a government agency. After being here for about a month, I have found that absolutely nothing is documented as far as configurations on our computer desktops. I would like to begin this process, but would like know if there are any standard forms that are used to document desktops on a computer.
Jeff
Jeff
RE: Configuration Management Documentation
I'm just on the learning slope for this application... I don't find it too difficult since I was one of the earlier users of Visual Basic... and currently use Delphi... the form objects and routines are similar for both.
Dik
If it is the former traditional tools like clearcase/clearquest are great. Some still use PDM for more manufacturing management. We use a custom interface built on top of MS access as "dik" mentioned. However, when we got to 15k relational elements we had some speed problems. We are now on a long slow conversion to clearcase, which itself uses someone's database underneath.
If it is the latter, perhaps a forum on IT would be more likely to bear fruit.
Good luck!
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
Steam Engine enthusiasts
Steam Engine Prints
