Assembly Dimensions
Assembly Dimensions
Assembly Dimensions
I have created an assembly of a simple 4-bar linkage in which all 4 arms of the linkage are the same length. One of the pivot points is fixed in the assembly and the one opposite it is constrained to the same plane so it can only travel in a straight line. I would like to constrain the movement of this assembly between two max and min dimensions. Is this possible?
Dblcrona
RE: Assembly Dimensions
limit mates in the advanced mates
