NX4 - Ugraf.exe - Entry Point Not Found
When I start with NX4, the warning appears:
The procedure entry point VDAC_ask_compliance could not be located in the dynamic link library libvdac.dll
When I finish with NX4, the error appears:
Faild to laad image - see log file for details
File name: C:\Program Files\UGS\NX 4.0\UGIMW\application\iwi_ufint.dll
Function name: ufusr
THX in advanced,
Best Regards,
Luka Lebar
RE: NX4 - Ugraf.exe - Entry Point Not Found
I'd call GTAC, if at all possible about this one.  If that's not an option, try re-installing NX4.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
First I tried to re-install NX4, but no changes, the problem still exist. Than I uninstall NX4, uninstall NX2 that I actual use it. Than I clean the registry and install NX2 once again, which work correctly as before and than install NX4 once again, but this was not mend
matters - no improvement.
Could anyone help me please!
Thank you Tim Flater to take your time, I am in
expectation of the answer from GTAC!
Luka Lebar
http://lebar-luka.blogspot.com/
