Various bolt drawings
Hi
Does anyone know of any good sites that have various bolt drawings or is there a lisp routine out there somewhere.
Thanks for your help in advance.
Taffcad
RE: Various bolt drawings
Check out Mcmaster-Carr.
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 01-18-07)
There should be some lisp programs available out there to do what you are asking about.  We collected data for specific inch size and metric bolts in an excell spread sheet and used ACAD to extract the data to draw simplified
bolts or threads, i.e. not spiral threads.  That worked for us but cannot share it as it is incorporated in a very large program.  We did have to enter the length of the thread or screw length.  Metric threads were a pain however as you could not simply use ratios for head diameters and head heights.
For nuts and heads, I drew up a "unit bolt head" and "unit nut" that measure 1" each dimension- I can then insert them with whatever X and Y scale I need to make a cosmetically acceptable bolt head or nut of any size.
I also use a lisp that is very basic, does bolt heads and nuts with washers in plan and elevation.  It makes the blocks on the fly and needs an external washer block and three data file.  I forget where I got it but it has been around for years, perhaps decades.  I'm not sure how to post the dwg files but here are the lsp and dat files.
(defun GETSIZE ()
 (initget 1 "B N")
 (setq HEX (getkword "\n<B>olt or <N>ut: "))
 (if (= HEX "B")
  (progn
   (prompt "\n1/4  5/16   3/8    7/16  1/2    5/8   3/4  7/8")
   (prompt "\n1.0  1.125  1.25   1.5   1.75   2.0   2.25")
   (setq SIZE (getstring "\nNominal Size of Hex Bolt: "))
   (BEGIN "D:/Acad/Lisp/HBOLT.DAT")
  (progn
   (prompt "\n1/4  5/16   3/8   7/16   1/2  9/16  3/4  7/8")
   (prompt "\n1.0  1.125  1.25  1.375  1.5")
   (setq SIZE (getstring "\nNominal Size of Hex Nut: "))
   (BEGIN "D:/Acad/Lisp/HNUT.DAT")
; start up routine
(defun BEGIN (DATA)
 (setq MPT (getpoint "\Insertion Point: "))
 (setq CK nil EN (entlast)
  FILE (open DATA "r")
    SL (strlen SIZE)
  LINE (read-line FILE))
 (while (and LINE (/= SIZE (substr LINE 1 SL)))
  (setq LINE (read-line FILE)))
 (close FILE)
 (if (not (member LINE '(nil "")))
  (if (= SIZE (substr LINE 1 SL))
   (progn (GETDAT) (setq CK T)))
  (prompt "\nRequested size not found!")
) (princ))
; get data from file
(defun GETDAT ()
 (setq BN (substr LINE 11 10))
 (STRBN)
 (setq S1 (atof (substr LINE 21 10))
       S2 (atof (substr LINE 31 10))
       S3 (atof (substr LINE 41 10))
       S4 (atof (substr LINE 51 10))
       S5 (atof (substr LINE 61 10))))
; get block name
(defun STRBN ()
 (setq LGTH 1 TSTR (strlen BN)
         CH (substr BN LGTH 1))
 (while (and (/= CH " ") (/= CH ""))
  (setq LGTH (1+ LGTH) CH (substr BN LGTH 1)))
 (setq BN (substr BN 1 (1- LGTH)))
 (if (= VIEW "EL") (setq BN (strcat VIEW BN))))
; draw nut or bolt in plan view
(defun C:HBOLTP (/ CK SS1)
 (V3)
 (GETSIZE)
 (if (= CK T) (progn
  (if (= (tblsearch "block" BN) nil)
   (progn
    (command "insert" "HBOLTP" MPT S1 S1 0
             "block" BN MPT (entlast) ""
             "insert" BN MPT 1 1 0)
   (command "insert" BN MPT 1 1 0)
(setq ANS (getstring "\nAdd washer <Y>? "))
(if (or (= ANS "") (= ANS "Y") (= ANS "y")) (WASHP))
(setq MPT nil)
(V4))
; draw bolt in elevation view
(defun C:HBOLTE (/ CK SS1 HEX SIZE)
 (V3)
 (setq VIEW "EL")
 (GETSIZE)
 (if (= CK T) (progn
  (setq ANG (getangle "\nRotation angle: ")
        ANG (angtos ANG))
   (progn
    (setq G1 (/ S2 2.0)
          G2 (/ S2 4.0)
          G3 (/ S2 8.0)
         PT1 (polar MPT pi G1)
         PT2 (polar PT1 0 S2)
         PT3 (polar (polar PT1 0 G3) (D90) S3)
         PT4 (polar (polar PT2 pi G3) (D90) S3)
        PT1A (polar PT1 (D90) 1.0)
        PT3A (polar PT3 3.66519 1.0)
         PT5 (inters PT1 PT1A PT3 PT3A nil)
         PT6 (polar PT1 0 G2)
        DIST (distance PT1 PT5)
        DIFF (- S3 DIST)
         PT7 (polar PT6 (D90) DIST)
         PT8 (polar PT2 pi G2)
         PT9 (polar PT8 (D90) DIST)
        PT10 (polar PT2 (D90) DIST)
        PT11 (polar PT1 (D90) DIFF)
       PT11A (polar PT1 0 G3)
        PT12 (polar PT6 (D90) DIFF)
        PT13 (polar PT8 (D90) DIFF)
       PT13A (polar PT8 0 G3)
        PT14 (polar PT2 (D90) DIFF)
        MPT1 (polar MPT (D90) S3)
    (setq en (entlast))
    (command "pline" PT10 "a" "s" PT4 PT9 "s" MPT1 PT7
             "s" PT3 PT5 ""
             "line" PT3 PT4 "")
    (if (= HEX "B") (progn
     (command "line" PT5 PT1 PT2 PT10 ""
              "line" PT6 PT7 ""
              "line" PT8 PT9 "" ))
     (progn
      (command "pline" PT11 "a" "s" PT11A PT12
               "s" MPT PT13 "s" PT13A PT14 ""
               "line" PT11A PT13A ""
               "line" PT11 PT5 ""
               "line" PT12 PT7 ""
               "line" PT13 PT9 ""
               "line" PT14 PT10 "")
    (MKSET)
    (command "block" BN MPT SS1 "")
    (command "insert" BN MPT 1 1 ANG)
 (if (or (= ANS "") (= ANS "Y") (= ANS "y")) (WASHE))
 (setq  MPT nil
       VIEW nil)
 (V4))
; draw washer in elevation view
(defun WASHE (/ CK SS1)
 (V3)
 (setq VIEW "EL")
 (BEGIN "D:/Acad/Lisp/AWASHER.DAT")
 (if (= CK T) (progn
   (progn
    (command "insert" "WASHEL" MPT S1 S2 0
   ) (command "insert" BN MPT 1 1 ANG))))
  (setq MPT nil VIEW nil)
  (V4))
; draw washer in plan view
(defun WASHP (/ CK SS1)
 (V3)
 (if (= CK T) (progn
   (progn
    (command "circle" MPT "d" S1
   ) (command "insert" BN MPT 1 1 0)
  (V4))
; select all entities
(defun MKSET ()
 (setq SS1 (ssadd) EN1 (entnext EN))
 (while EN
  (setq SS1 (ssadd EN1 SS1)
        EN1 (entnext EN)
         EN EN1
(defun D90 () (* pi 0.5))
; defint V3
(defun V3 ()
 (setq BM (getvar "blipmode"))
 (setvar "blipmode" 0)
 (setvar "cmdecho" 0)
 (command "undo" "group")
(defun V4 (/ BA)
 (setvar "blipmode" BM)
 (command "undo" "end")
 (prompt "\n")
 (setq BA "Program completed . . . . .")
data files:
 HNUT.DAT
Hex nuts
SIZE      BN        F         G         H
1/4       1-4HN     0.438     0.505     0.226
5/16      5-16HN    0.500     0.577     0.273
3/8       3-8HN     0.562     0.650     0.337
7/16      7-16HN    0.688     0.794     0.385
1/2       1-2HN     0.750     0.866     0.448
9/16      9-16HN    0.875     1.010     0.496
5/8       5-8HN     0.938     1.083     0.559
3/4       3-4HN     1.125     1.299     0.665
7/8       7-8HN     1.312     1.516     0.776
1.0       1HN       1.500     1.732     0.887
1.125     1_1-8HN   1.688     1.949     0.999
1.25      1_1-4HN   1.875     2.165     1.094
1.375     1_3-8HN   2.062     2.382     1.206
1.5       1_1-2HN   2.250     2.598     1.317
HBOLT.DAT
Hex Bolts
Size      BN        F         G         H
1/4       1-4HB     0.438     0.505     0.188
5/16      5-16HB    0.500     0.577     0.235
3/8       3-8HB     0.562     0.650     0.268
7/16      7-16HB    0.625     0.722     0.316
1/2       1-2HB     0.750     0.866     0.364
5/8       5-8HB     0.938     1.083     0.444
3/4       3-4HB     1.125     1.299     0.524
7/8       7-8HB     1.312     1.516     0.604
1.0       1HB       1.500     1.732     0.700
1.125     1_1-8HB   1.688     1.949     0.780
1.25      1_1-4HB   1.875     2.165     0.876
1.375     1_3-8HB   2.062     2.382     0.940
1.5       1_1-2HB   2.250     2.598     1.036
1.75      1_3-4HB   2.625     3.031     1.196
2.0       2HB       3.000     3.464     1.388
2.25      2_1-4HB   3.375     3.897     1.548
 AWASHER.DAT
Type A plain washers
SIZE      BN        B         C
6         6AW       0.375     0.049
8         8AW       0.438     0.049
10        10AW      0.500     0.049
3/16      3-16AW    0.562     0.049
12        12AW      0.562     0.065
1/4       1-4AW     0.625     0.065
5/16      5-16AW    0.688     0.065
3/8       3-8AW     0.812     0.065
7/16      7-16AW    0.922     0.065
1/2       1-2AW     1.062     0.095
5/8       5-8AW     1.312     0.095
3/4       3-4AW     1.469     0.134
7/8       7-8AW     1.750     0.134
1.0       1AW       2.000     0.134
1.125     1_1-8AW   2.250     0.134
1.25      1_1-4AW   2.500     0.134
1.375     1_3-4AW   2.750     0.165
1.5       1_1-2AW   3.000     0.165
1.75      1_3-4AW   4.000     0.180
2.0       2AW       4.500     0.180
2.25      2_1-4AW   4.750     0.220
