Slowing an Animation
I currently have a pretty large animation. The problem is it is moving too fast. Is it possible to double the time it takes to move without having to move each key individually?
Bill
RE: Slowing an Animation
Which SW version?
Do you mean with the SolidWorks Animator add-in or the built in Explode/Collapse animation?
cheers
Its with the add-in. Solidworks 2006
If I remember correctly, in the key frame editor, you can drag the timeline using the top right key point. This should automatically scale all other points in the timeline. So if you want it half speed make the timeline twice as long.
