How to cancel a job running in background
Dear all,
I am running a job on a UNIX server of my university with:
      nohup ansys100 -b -i XXX.inp
But now I find a mistake that cause Ansys run forever!!!
Could you please tell me a way to stop it.
Thank you very much.
RE: How to cancel a job running in background
Can't you kill that process via telnet?
I don't know the command to kill. Could you tell me ?
this would be an "inconditional" stop which would cause the "irregular" shutdown of Ansys and the loss of the calculated data. It's OK for linear analyses, but not the recommended way for non-linear.
If you want to perform a restart, you can place a text file named "<jobname>.abt" in the working directory. You have to write the word "nonlinear" without quotes on the first row, starting at column 1. The execution will stop after the current equilibrium iteration.
