type of steel Material for make endmill tool holder R8
I'm look type of steel Material for make endmill tool holder R8 .
what type of material for make toolholder insert to Quick tool change holder.
Thank Mark
Thank Mark
RE: type of steel Material for make endmill tool holder R8
If you are looking for a speical holder you can go outside of the common supply houses and find something more to your liking. Remember that a milling tool holder also locates a tool in the center of the spindle. Is your toolroom that good that they can make this type of tool with very low (.0002") axial runout?
I am lucky with a full staff of toolmakers and tool grinders who can work to .0001" on a daily basis but few have this resouce avaialble. When I have to have the tool room make a tool it is at a rate of over $75/hr, so if I need a special tool I will get one that is close to the form I want and have it modified.
What about heat tritment ?
What steps for making special R8 tool holders ?
Mark.
