wall thickness analysis
Does Solidworks have a tool that makes it as easy to check wall thickness of a part as it is to check draft?
How do you usually do it?
RE: wall thickness analysis
Yes, there's a "Thickness Analysis" option included with the SolidWorks Utilities add-in.
thank you
I do not have that add in. So I'll have to do it manually.
If you have to do it manually I would recommend making a drawing with a lot of section views.
That's something I normally track while building the model.  In complex parts I'll label my shell and rib features with the thickness (such as Shell-0.080)--keeps things simple along the way.  I like dgowans' suggestion if you're working with imported stuff.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe transcends reason.
that was the plan
