Is it safe to use different versions of ProE to work on one file?
Is it safe to open and work on the same proe file with different versions of proe (e.g. one site @ m010 and another site @ m040)?
TIA
TIA
RE: Is it safe to use different versions of ProE to work on one file?
Best Regards,
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he'
"I would say you are safe but I would find out what the differences are between the two builds.....making sure their are no major chances." This is the problem I dont know how to find this out :)
http://w
As far as I know there is no problem exchanging files between different cuts of the same version of Pro/E.
Good Luck
The advisor is a good place to start if you are seeing problems.
I have users on 4 builds of WF2, as I try to bring everyone up to newer builds.
Ben Loosli
Sr IS Technologist
L-3 Communications
Stick with the same datecode if possible. It will save you much headache and pain.
Good Luck,
steve
