Renaming parts in PDMWorks
I think I know the answer, but I want to make sure. I've got an assembly that midway through the design, several sub-assemblies were changed. In those subs, several parts ceased to be used. Now at the end of the design, I want to rename all the components in sequential order (we won't go into the pro's and con's of this now
My question is: Will PDMWorks update the references for an old revision, even if the component no longer exists in sub X and is now a different name? E.g. Component X initially was in sub A. After the revision, Component X no longer exists in sub A, but is now in sub B and has been renamed to Y. If I open sub A at an earlier revision as built, will component X (which is now Y) open at the earlier revision? Correctly?
I hope this isn't too confusing; feel free to question me further.
I'm running SW 2007sp2.0
Craig Sink
Mechanical Engineer
Force Design, Inc.
www.forcedesign.biz
RE: Renaming parts in PDMWorks
That being said, you may want to create a simple assembly to test it first. Make TestAssembly which includes TestPart. Check both in. Remove TestPart from TestAssembly. Check TestAssembly in. Rename TestPart to TestPart1 from within the vault. Get the original TestAssembly from the vault and see what it part it has.
Eric
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 10-27-06)
