Meshing volumes
Meshing volumes
Hi all,
I have some problems with mapped meshing. I would like to create brick mesh with regularity on boundary areas (inlet, outlet, top, left and right, bottom with finest mesh) as well as on object areas(finest mesh).
How can I do that?
Thanks a lot,
Robert
And the geometry:
/prep7
ET,1,FLUID142 !element type
MPTEMP,,,,,,,, !material properties
MPTEMP,1,0
MPDATA,DENS,1,,1.25
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,VISC,1,,1.79e-005
BLC4,0,0,2.35,17.723,51.5
BLC4,109.65,0,2.35,17.723,51.5
CYL4,56,-41.525,78.525,46.6143,81.525,133.3857,51.5
btol,0.001
vadd,all
BLOCK,-224,672,0,240,-103,154.5,
vsbv,1,4
How can I do that?
Thanks a lot,
Robert
And the geometry:
/prep7
MPTEMP,1,0
MPDATA,DENS,1,,1.25
MPTEMP,,,,,,,,
MPTEMP,1,0
btol,0.001
vadd,all
vsbv,1,4
RE: Meshing volumes
It's not so simple. This code generates your geometry so it can be mapped meshed, but the problem ist at the corners of the cylinder, where small lines are builded. It can be meshed but with very small elements.
CODE
et,1,45
btol,0.001
vovlap,all
BLOCK,-224,672,0,240,0,51.5
vovlap,all
asel,s,loc,z,0
vext,all,,,,,-103
asel,s,loc,z,51.5
vext,all,,,,,154.5-51.5
vsel,s,loc,z,0,51.5
vsel,r,loc,x,0,112
vsel,u,,,2
vdele,all
vsel,all
esize,5
vsweep,all
Alex
