3rd Angle Projection in drawings
When projecting views on a drawing how can I set my drawing standard for projection type. SW seems to be defaulting to 1st angle projection and I want to use 3rd angle projection. Is this even possible?
Ken Johnson
Ken Johnson
RE: 3rd Angle Projection in drawings
Right click in a blank area of your drawing and select properties. In the upper middle of the Sheet Properties there is an option for setting Type of Projection.
SA
Is there a way to set this as a default setting?
Ken
SolidWorks 2007 SP1.1
Intel Xeon 2.8GHz 4GB Ram
NVIDIA Quadro FX3000
