preparing for conducting process equipment performance tests
How can I start preparing for conducting process equipment performance tests like pump performane tests?
Do you recommend any resources i.e. books, or specific industrial code requirements?
RE: preparing for conducting process equipment performance tests
ghamsa,
from an operational and safety point of view "Guidelines for Safe Process Operations and Maintenance" (ISBN 0-8169-0627-0) should be one of your choices.
Kind Regards,
hahor
The Hydraulic Institute would be a good start
http://www.pumps.org/
plasma,
Specifically, what equipment will be tested ?
There are industry-sanctioned performance tests developed by various industry groups, for example:
Boilers  -  ASME performance test Code
Cooling Towers  -  Cooling Tower institute
Pumps  -  Hydraulic instritute/Pump vendors
Deaerators  -  ASME Performance Test code
etc
be specific !!
-MJC
Thanks for your answers. In fact, I was looking for one reference for all.
The answers I receive are of great help.
Thanks all.
