*vplot command
*vplot command
*vplot command
I have a table dimensioned *dim,tab_1,a,b,c filled with results. I would like to plot these results over the planes (index c) I mean plot "a" for b=1 and each "c", but *vplot command works only with "a" and "b"....So I defifed another table *dim,tab_2,a,c and try to fill this table by values from tab_1 as follows :
*DO,_S,1,c
   *DO,_T,1,a
      tab_2(_T,_S) = tab_1(_T,1,_S)
   *ENDDO
*ENDDO
...but when I open tab_2 the entire first column is filled wiht same value - last value from tab_1(a,1,1) and second by tab_1(a,2,1)....
RE: *vplot command
there is a mistake in last sentence - correct is :
...but when I open tab_2 the entire first column is filled wiht same value - last value from tab_1(a,1,1) and second by tab_1(a,1,2)....
