Aeration system for Compostor
Guys,
Please someone offer some guidelines for the design of aeration system for an in vessel compostor used for composting organic waste?I am looking for advice on spacing of aeration grates,velocities,pressure drop,methods of flow control etc etc
RE: Aeration system for Compostor
You probably want to use a pd type of blower. The aeration piping would consist of drilled piping installed in a gravel bed. Use a perforated floor under the compost.
In-vessel compost systems was tried about 20 years ago and discarded because of the excessive equipment cost. It is difficult to control the air flow since the compost will shrink and crack as it biodegrades.
The aeration rates are the same as conventional composting. The only difference is how the composting system is loaded and unloaded.
Will the compost get into the aeration holes and eventually block them?Can we protect the holes from choking up
How do we ensure uniform air flow out of the pipe throughout its lengh(about 7 meteres)
The material is supposed to be placed into the top of these units and theoretically should be evenly spread across the top. As the compost degrades and loses moisture, the volume decreases, such that you will get craters, low areas, and pulling away from the walls.
These issues will cause short circuiting of the aire flow.
Be aware that odors from these compost units is intense, so you need odor control equipment.
