Need Help with outputs - New to Matlab
hello,
i am trying to write a program in Matlab to generate psuedo-random ip's.  i am having problems with the output funcions.  it keeps putting out IP addresses that are not in the target range into my file.  can anyone help me?
% N is the total # of IP adresses
% n is the total # of potential victims
% The target IP is a number between 1 and 16,777,215
%       set to be 1
% M is the maximum # of iterations
% K is the number of trials
function [TargetInfectTime,VictimInfectTime] = IPsim(N,n,M,K)
TargetInfectTime=M*ones([1,K]);
infected=1;
VictimInfectTime=[];
address=[];
for j=1:K
    for i=1:M
        IP = ceil(N*rand(1,infected));
        if sum(IP==1)>=1
            TargetInfectTime=i; break
            else if sum(IP<=(n+1))>=1
                infected=infected+sum(IP<=(n+1));
                VictimInfectTime=[VictimInfectTime i*ones(1,sum(IP<=(n+1)))];
                address=[address IP];
            end
        end
    end
    results=fopen('results.txt','w');
    fprintf(results,'Number of Machines Infected %10.0f\n',infected);
    fprintf(results,'Target IP Infected %10.0f\n',TargetInfectTime);
    fprintf(results,'Victim Infected %10.0f\n', VictimInfectTime);
    fprintf(results,'IP Address %10.0f\n', address);
    fclose(results)
    end
end
RE: Need Help with outputs - New to Matlab
Student posting is not allowed.
Additionally, you've given ZERO information about what you think you're supposed to be getting, and what you're actually getting.
TTFN
Sorry, i forgot to add what the issues were.
What i am expecting to see is the IP address output when it is hit.  the problem is it not only prints out the IP address less than n that caused it to enter the else if loop, it also prints out additional random IP addesses.  there seems to be no pattern to why it is doing this.  sometimes it prints out four or five additional IP addresses above the "n" value, other times it prints out 10 or more.
this is not an assignment for class, it is to further some research on random IP generation.
Well, it looks to me like the results are consistent with your program, so you need to revisit what it is that you think your program is supposed to do.
TTFN
Thanks for the help!
