Changing default units in wildfire 2?
Hello, I'm trying to change the default units in Wildfire 2. At the moment it's the default imperial units whereas I want mmNs, is there anything I can do to change it so that it uses mmNs by default?
RE: Changing default units in wildfire 2?
You can set the config option
PRO_UNIT_SYS mmns
or you can make a default start part and set it however you want.
