Move face, Delete face....Where did they go?
I'm working on an old model that had all the parameters removed. Can't find a couple of the operations that used to be in the Edit Face toolbar: Delete Face and Move Face.
Anyone know where the buttons are?
'ziner
RE: Move face, Delete face....Where did they go?
They are still located on the Edit -> Face... dialog.  However I suspect that, like an earlier poster here, you are using a 'Role' that is not using Full Menus.  Simply go to the Roles pallete and select one of the 'Roles' with a notation that it is "with full menus".
John R. Baker, P.E.
Product 'Evangelist'
NX Product Line
UGS Corp
Cypress, CA
http://www.ugs.com
Thanks much. An incidental benefit from following your advice: the icons shrank to "small" size, as I had selected as a preference before, but never occurred.
