View dependantly edited curves re-appearing by themselves.
In UG NX3 when I view dependent edit curves periodically UG will create new view dependent curves in the place of where I edited the model based curves to show the image that I want. I hope I'm describing this clearly. To give an example, I create a view on drafting, use "View Dependent Edit" to trim some curves back to show a break-away view. At some point later, I may open a new sheet, or make a modeling change. When I come back to drafting mode, UG has created it's own curves in the view, not the model, that sit where the old model b ased curves were that I got rid of. It's very annoying, I have to keep cleaining up the views whenever I make changes.
I'm not the only one, it's seems to bea happening to many of my co-workers as well.
Any insight, has anyone else seen this happen?
RE: View dependantly edited curves re-appearing by themselves.
'ziner
I would expect this behavior if you're making model changes/edits and the views are updating with new edges to display, but not under any other circumstance. Maybe the view updates just aren't as complete as they used to be. Probably a good idea to contact GTAC if you don't get the problem resolved on your own.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
