Default Tool Settings
Does anybody know how to set defaults in the tool settings? For example, have Match Element Attributes have Level, Color, Line Style, and Line Weight all checked everytime you open Microstation. By default, those attributes are all unchecked everytime I open the program, I'd like to change that, so my users and I do not have to keep changing the tool settigs daily.
Thank you for any input.
Dave
Dave
RE: Default Tool Settings
Namdac
Any other suggestions?
Thanks again.
No, never found the solution. The save settings didn't seem to save what I wanted to.
Thanks for following up.
Instead of one macro for each tool you want settings changed
just merge all the macros you have created for your tool settings for each tool and in the last line just before closing the macro put in
[mdl unload [toolname]]
Then name this megamacro "settings.bas"
then change your startup to run this macro on starting ustn
that way you'll have all your prefered settings enabled.
without invoking the save settings on exit.
you'll find instructions on how to do that
at http://www.askinga.com/article.asp?articleID=116
I'll be publishing more of these type tips and tutorials in the Microstation magazine Control Alt Delete you can find out more about this at http://members.ozemail.com.au/~penbrush/
