Quick Disconnect Coupling
I'm looking for some quick disconnect couplings made from plastic. They can't have any metal in the flow path, eg. no springs. I have found some on Colder.com but I need to get 2 sets which won't interchange with each other.
For example, one set will have a 3/4" hose tail and the other set will have a 1/2" hose tail but we don't want the heads to be able to interchange.
Can anyone recommend a supplier other than colder who make quick disconnect couplings as described above.
God bless.
God bless.
RE: Quick Disconnect Coupling
ht
Russell Giuliano
How about color coding? Or different tube diameters, thus different connectors?
It would be slow removing tubing on a constant basis but thanks for the idea.
I've gotton a reply from kentsystems.com but again they don't seem to have a coupling with no springs in the flow path. Seems Colder are the only company who do this. Their NSH series has a spring alright but it's not in the flow path. If we could get another coupling with 3/4" hose tail but which won't be interchangeable with the NSH series we'd be 'on the ball' as the man says.
All couplings on newage are cam operated. We juist want a quick disconnect snap fitting.
