however,
however,
Tech pubs guy at my last place drilled into me that it is alway "however,".
I just had a discussion with several colleagues about this.
Was the tech pubs guy correct or was he, and hence I, wrong?
RE: however,
In principle though should there always be something after the word "however".
RE: however,
Maybe a question mark!
(I'm just joking.)
RE: however,
http://ow
RE: however,
In your example though it doesn't look like a "," would be appropriate.
RE: however,
RE: however,
I was responding to crysta1c1ear's example, yours hadn't posted when I was writing mine.
Don't you hate it when that lag happens and you look like an idiot, I'll have to learn to type, and think, faster!
RE: however,
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 10-27-06)
RE: however,
If 'however' is being used to join two independent clauses, (conjunctive adverb) then it should have a semi-color before and a comma afterwards.
He went to the store; however, he did not buy any goods.
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
RE: however,
RE: however,
For me "however" is employed in the end of a statement or idea that can have aside effects whatever they are
Cheers
Luis
RE: however,
RE: however,
"However" doesn't have any punctuation built into it. It's just a word with a role to play in the sentence.
Hg
Eng-Tips policies: FAQ731-376
